2015-05-07 3:54 AM
Has anyone tried to use the temperature sensor on STM32L1 devices with the latest CubeMX and library?It's giving me bogus results (-2C on my desk), while on older versions it worked normally.Chip is STM32L151RCT6 and the compiler IAR 7.40.The project is a test project containing only CubeMX generated code for the GPIO and ADC and the temperature calculations from AN3964.Tried Vref channel on a separate project and it measures the correct VCC (3V3).Thanks!George #cubemx #temperature #stm32l12015-05-18 6:51 AM
Hi George,
Could you please tell me what is the ''older version'' for which project was working as expected?-Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
