2022-06-08 11:17 PM
i can't no longer open my ioc file. In my case its name is MIPControl. My projectname is mipcontrol. I know to change the name of the problem should fix it. But in my .project file the name is already set to MIPControl.
When i rightclick on my project and rename it manually to MIPControl i can open the ioc file agin. BUT when i rename it the git repo will be deleted from egit und there is no git repo i can use (i use git in my konsole)
Does anyone know where the information is stored that the io file has to be ***.ioc?
2022-06-09 10:11 AM
Use the standalone CubeMX. It is free of silly nuisances of the CubeIDE plugin. Name your .ioc files as you want.
Really? You have not pushed the repo to a remote server (github)?
2022-06-09 12:14 PM
just the local repo ;) I push every day after work but renaming the Project name cause complete delete of the local repo
