  • 1756 Views
STM32CubeMX and HAL Libraries Version (F1 for my case)
Posted on September 02, 2015 at 04:35Hello,I just start using STM32CubeMX three days ago and the product is looking good! I'm playing with a Nucleo Board STM32F103RB and one thing that I noticed is that the HAL Library for F1 version downloaded by C...
kopf by Associate II
  • 2009 Views
STM32CubeMx Adding own plugin.
Posted on July 24, 2015 at 14:41Hello, I am developing own RTOS for STM32. I see that CubeMX is a very useful tool for generating SW configuration. Is there any possibilty to add my OS to CubeMX configuration? I saw that configuration of IP packages...
slawek by Associate III
  • 766 Views
STM32CubeMX 4.9.0 TIM Config Bug?
Posted on August 04, 2015 at 18:20 The generated config code ''MX_TIM3_Init()'' in ''src/tim.c'' for TIM3_PWM_Output on channel 1 and 2 fails in ''HAL_TIM_PWM_ConfigChannel()'' at assert_param(IS_TIM_OCN_POLARITY(sConfig->OCNPolarity)); a...
arohrer9 by Associate II
  • 1792 Views
STM32CubeMX CAN problem
Posted on August 26, 2015 at 10:08 Hello, I have 2 STM32F042C6 board. My transmitter board's code : static CanTxMsgTypeDef TxMessage; // Static variable declaration static CanRxMsgTypeDef RxMessage; /* CAN init function ...
STM32Cube_FW_F0_V1.2 versus 1.3
Posted on August 19, 2015 at 21:12It is becoming annoying that since ST's inception of a Cortex implementation there have been Standard Peripheral libraries that simply are not standards to rely on.I thought that switching to the HAL libraries would...
rbenesh by Associate II
  • 1454 Views
erroneous call of free() in usbd_conf.c
Posted on August 12, 2015 at 17:07The STM32CubeMX software generates a USB stack with a call to free() in usbd_conf.c. If you disconnect USB by calling usbd_stop() the software crashes here as there is no free from stdlib or there is no correctly de...
joerg2 by Associate
  • 747 Views
STM32CubeMX: Possible bugs in ethernet configuration
Posted on July 30, 2014 at 10:30Hi, In the last few days I have spend few hours trying to setup FreeRTOS + LwIP TCP/IP stack. Now it is finally working (UDP echo, ICMP ping), but I believe there might be some bugs in STM32CubeMX. - Interrupt prior...
crt by Associate II
  • 2685 Views
Stm CubeMX, NucleoL152 and SD Card Shield
Posted on July 06, 2015 at 18:20Hi to all, i'm a newbie of programming embedded, i have a Stm nucleo L152RE and i a sd card shiled v 4.1 of seeed studio this is thehttp://www.seeedstudio.com/wiki/SD_Card_shield_V4.0 of shiled. Now i want use cubemx ...
antonio23 by Associate II
  • 3395 Views
