  • 1756 Views
Resolved! STM32CubeMX usb_device.c customization points?
Posted on July 02, 2017 at 02:49I am using STM32CubeMX 4.21.0 with the STM32L4 HAL library version 1.8.1.It seems that the Src/usb_device.c includes code with customization points (e.g. HAL_PCDEx_BCD_Callback() has a user code comment block) but the...
Publish the CubeMX repository on Github?
Posted on January 18, 2018 at 16:31Since ST already https://github.com/STMicroelectronics, could you consider publishing there the CubeMX repositories content?So that users could clone the Cube BSPs and libraries into their projects, as git sub-modu...
Pavel A. by Super User
  • 1707 Views
CUBEMX RCC settings unfunction
Posted on March 03, 2018 at 07:46I am using STM32CUBE V1.0 Version 4.24.0I am using STM32F107VC.In the RCC settingsFor the purpose to know the what code has been modified.I use WinMerge to compare the outputs.I enable the [1] (mark by yellow) and [3...
I2C - generated CubeMX
Posted on March 28, 2017 at 22:56Hello, I still tried with I2C on nucleo F401RE. I am use STM32CubeMx for generate files, but my program is not working. I  want send three bytes on I2C in blovking mode. This is my code: I2C not working, still is log...
Sigh - another CubeMX bug...
Posted on February 27, 2018 at 01:04Version 4.24.0 STM32CubeMX - STM32F303RCTx has pin 18 as PF4 instead VSS - thought I had an extra signal!!#cubemx-v4.24
Bug reporting: USB CDC: Using non-initialized dynamic memory
Posted on February 25, 2018 at 00:06DUT:Device: STM32F407VGTBoard: STM32F4-DISCOVERYPC part:OS: Windows 10Driver: USB Serial Device, Microsoft, 6/21/2006, v10.0.16299.15Initialization code is generated using the STM32CubeMX Version 4.24.0 with STM32...
zoromgerg by Associate II
  • 1825 Views
Why is HAL documentation lacking?
Posted on February 02, 2017 at 11:40The ST HAL should make programming STM32 microcontrollers easier. After all, it is a 'Hardware Abstraction Layer'. It provides an interface to the user, so he doesn't need to manipulate the hardware registers dire...
[proposal] Public STM32CubeMX issue tracker
Posted on December 14, 2017 at 13:10There are lot of bugs in STM32CubeMX and its components. Having public issue tracker will simplify the situation with reporting all issues and tracking their status.Idally, having public source code of STM32CubeMX...
