  • 1756 Views
KEIL very slow with CubeMX
Posted on January 29, 2018 at 20:33Hello!I am using KEIL MDK 5 and it is compiling very very slow.CubeMX  v4.24STM32CubeF4 v4.19.Any ideas  ??ThanksSasha#cubemx-4.24 #keil-mdk5
Sasha A by Associate II
  • 7723 Views
  • 14 replies
Resolved! Why __FPU_PRESENT and AMR_MATH_CM4 are not defined for TrueStudio projects generated in STM32CubeMX?
Each time I add __FPU_PRESENT and AMR_MATH_CM4 to symbols to get project compile properly, yet getting 30 warning about __FPU_PRESENT redefined.Project is made straight-forward: configure pins, select TrueStuido, pressing "generate code". Opening pro...
SDMMC module does not answer used with FatFS
Hello I'm testing implementation of sdcard / FatFS on F446.First I started with the example. It works.Now, I'm trying to implement a basic test app created from scratch with CubeMx.I configured a simple project with fatFS, SDIO, no DMA, no OS.int mai...
JulienD by Senior
  • 1269 Views
stm32l4xx internal flash + data for the single byte program
Hi all,I am using stm32l486 MCU and trying to use stmcube internal flash example code. As i see we have API "HAL_FLASH_Program" to program word or double word. Is it possible to write byte data by doing type casting and increasing the address by 1?Co...
John3 by Associate II
  • 3406 Views
Package Location for V5.0.0
After the latest CubeMX update, where are the packages now stored? I have been using revision control on 'C:\Program Files\STMicroelectronics\STM32Cube\STM32CubeMX\packages' and am curious, I no longer see updates here
Justin1 by Senior
  • 1231 Views
Getting Started with Examples
How can I access the example peripheral projects for the STM32F091RC? I am using TrueSTUDIO & System Workbench and have looked exhaustively, are these available?
Justin1 by Senior
  • 1302 Views
