  • 1756 Views
Fatal Error while building the project
Hello All,While building my project, I got 3 errors as shown below. I have no application level errors.Error Messages: In file included from ../STM32GENERIC-master/tools/win/src/upload-reset/upload-reset.c:29:0:c:\st\stm32cubeide_1.4.0\stm32cubeide\p...
SP.19 by Associate II
  • 3169 Views
Bug Report: Folder Omission
Hello dear developers, here is a ridiculous bug I have found.Procedure for reproduction:1) Open STM32CUBEMX =) (preferably 6.1.1)2) Create a project. (preferably name it test)3) Generate source files.AN IMPORTANT STEP4) Copy the whole folder (If in w...
Resolved! How is the Timer Output Chanel linked to a Pin?
I have been following along with https://www.youtube.com/watch?v=-AFCcfzK9xcand I can see that each change made in CubeMX produces changes in my generated code in main.cHowever, I cannot find any generated code which links the Timer Output Channel 1 ...
GWood.1 by Associate II
  • 2030 Views
USB and compiler problem
HelloI dont know what is the problem that when I compile my code with Keil, the USB works nicely,but when I use cubeide compiler, the usb doesnt work. Both codes are generated by cubemxwhen the code compiled by cubeide, the usb is recognised, but com...
Resolved! [SOLVED] Automatic switching view for CubeMX file is buggy
Hi,when switching from e.g. a C file to CubeMX file, the view is changed to Device Configuration view. This is also the case if the CubeMX file is already opened in the IDE. Closing the CubeMX file also restores the view back.However, switching to a ...
RAltm by Senior
  • 1463 Views
