  • 1756 Views
How to connect the display using FSMC?
Dear professionals, please give me help if possible.I'm just starting to study the F4 series. I can't connect this display and initialize SSD1963. I'm trying to move the project from Keil to CubeIDE and from F103 to F407. I did everything (almost cor...
Wsitc.1 by Associate II
  • 2182 Views
Resolved! Should these be these?
I found these prompt in my "main.c" of NonSecure generated by MX for NUCLEO L552ZE-Q: /* USER CODE BEGIN WHILE */ while (1) { /* USER CODE END WHILE */   /* USER CODE BEGIN 3 */ } /* USER CODE END 3 */ }should it be this? /* USER CO...
MQi.1 by Senior II
  • 1680 Views
Resolved! Where are the smps LDO settings in the configuration tool?
Configuration tool auto generated code SystemClock_Config() calls HAL_PWREx_ConfigSupply(PWR_DIRECT_SMPS_SUPPLY). For my hardware i need to use PWR_SMPS_1V8_SUPPLIES_LDO with no voltage scaling. I cannot find where to change the power supply config...
TFran.4 by Associate II
  • 1609 Views
STM32H745iit Difference between CUMBEMX and datasheet pin 48
There is a difference between CubeMx and the datasheet. from Pin48https://community.st.com/s/?t=1610970558389Datasheet - STM32H753xI - 32-bit Arm® Cortex®-M7 400MHz MCUs, up to 2MB Flash, 1MB RAM, 46 com. and analog interfaces, crypto page 56/252Data...
Hans T by Senior
  • 937 Views
Resolved! STM32CubeMX latest version Bug?
Hello,I have just updated to the latest: STMECubeMX to version 6.1.1. and STM32CubeF1 Firmware Package V1.8.3 / 20-October-2020. Part Number: Stm32f103RCTx. And I have found the bug - probably ? When you use SDIO and define it as 1bit, the CubeMX...
RnnKrk by Associate II
  • 1767 Views
