  • 1757 Views
Resolved! STM32CubeMX clock setting
Hi,I am using STM32F469 discovery kit for a audio processing study. I am using STM32CubeMX (ver 6.2.0) for project setup and init code generation. In my application, I found a clock sync problem on MIC and Codec Playback. After some tracings, I fo...
YChan by Associate
  • 5654 Views
Resolved! STM32CubeMX, STM32F34R8 autogenerated project for TrueStudio. Prescaler for APB2 is setting the prescaler for APB1
Hello All,I tried to generate a test project with STM32CubeMX version 6.1.2 for micro STM32F334R8. I setup my project to generate mostly LL libraries, when setting the clock configuration, HSI (8MHz RC) is enabled, AHB prescaler is /8, then APB2 pres...
ClaudiaP by Associate II
  • 2140 Views
LwIP DHCP request not working on STM32F7
Hi all,I am trying to get LwIP running on my STM32F769I-Discovery board. It works fine with the provided netconn-example.But when I try to generate a new project inside CubeIDE the dhcp-discovery is always failing. I can not see anything when running...
Resolved! Serial Wire debug problems
I'm working on a low power project using the Stm32f103 (blue pill) and I've been having problems, which I'm pretty sure are related to Serial wire debug , I am using a low frequency ( 256 pre-scaler) to save power on the HCLK , and every time I attem...
HAbay.1 by Associate III
  • 4199 Views
How to update only HAL usart drivers in my program ?
I have used stm32cubemx v5.2 to create my project .Now i want to update only Uart drivers to drivers of cubemx V6.3 (latest drivers)How to do it ?Is it safe to just replace ?stm32l0xx_hal_uart.c and stm32l0xx_hal_uart.h with newer drivers ?
SA.17 by Associate III
  • 1650 Views
