  • 1757 Views
Resolved! Code generation fails on ArchLinux with OpenJDK 18.0.1.1
My code generation fails with the following exception :Exception in thread "Thread-4645" java.lang.IllegalAccessError: class parsers.FromScratchParser (in unnamed module @0x6a84a97d) cannot access class com.sun.org.apache.xerces.internal.parsers.DOMP...
JPOID.1 by Associate
  • 2637 Views
Hi STMicroelectronics! I am using your STM32F429 DISC1-DISCOVERY board. I am facing trouble to debug the code which I have generated without using HAL / Cubemax.
The program is uploaded to the board but still unable to view the printf function data on SWO. I have soldered the SB9 to view data on SWV/ SWO pin but still unable to see the printf data on ITM SWV data console.The rest jumper status are:SB4, SB6, S...
Resolved! Will GPDSC option be removed in the near future in STM32CubeMX?
I get this message whenever I try generating code with the "Other Toolchains (GPDSC)" in STM32CubeMX:The support of the “Tool chain / IDE�? you have selected will be soon discontinued in further STM32CubeMX version.If you want to benefit from further...
SMade.1 by Associate
  • 3480 Views
Stm32-nucleo-f401re-1.44-inch-oled-st7735
I try to drive ST7735 oled display with nucleo board. I worked with a ready-made example I found on the internet, but I could not print anything to the screen. When I compile my code, I don't get any errors and my screen is getting power. Is there a ...
Mboyr.1 by Associate
  • 1007 Views
When I setup the RANK for the ADC I want to read TemperatureSensor, VRef, IN0, IN1. But the order appears IN1, TemperatureSensor, Vref, IN0
In the MX program I set up the rank. to scan 4 values. TemperatureSensor, VRefint, IN0, IN1.I Initially saw this in DMA mode, But see it also happens in Discontinuous Mode. But when read the order is off by 1 position. It looks like it is reading IN1...
KiptonM by Lead
  • 2136 Views
