2022-03-09 5:39 AM
I tick the "Run after programming" option. Normally this works fine. User code gets going after programming. I create projects using Cube MX. With latest Cube MX (Version 6.4.0) code, after programming control is not going to user code. I have to now change the BOOT selection jumper and press reset. Then only user code is being executed. I never faced this problem before with earlier version (I don't have the older version number, as I upgraded Cube MX). I took one of my earlier projects and changed the code to test this feature manually and it works fine. Soon after downloading the code control transfers to user code. Can someone point out why this is happening and what is the solution please? Thank you for your valuable time.
