2020-04-06 3:20 AM
For using need .axf file, not found in my project((. How receive it file? May be need more IDE settings?
2020-04-15 5:08 AM
2020-04-15 5:15 AM
The folder field is a free text field, you have to enter manually the path corresponding to the Debug folder of your IDE project.
On macOS, it is not started by "C:\Users\<your-user-id>\...." but rather by "/Users/<your-user-id>/...".
Generally speaking on macOS, the root directory is accessible from "/"
2020-04-15 5:34 AM
manualy all ok! only my projects in ICloud/Documents and I not found in my Mac this folder ??? - copy-paste project folder to User directory and manualy .......
Thank you!!! Will be check futher )))
2020-04-15 5:46 AM
check -- copy/paste dont work for folder path ((((((((((((( only manually ((( wery bad software
2020-04-15 6:19 AM
Sorry I don't understand why your copy/paste doesn't work for folder path.
Could you please copy/paste your the folder path here ?
Do you still face issues with copy/paste if your project folder is not on Apple cloud Documents.
For information, on macOS, the cloud "Documents" folder is accessible from the terminal under :
/Users/<userid>/Library/Mobile Documents/com~apple~CloudDocs/Documents/
2020-04-15 7:49 AM
founded in google how copy folder/file path -- all ok if copy folder/file pass then paste to any file
But if paste to Monitor --- no anything ((( == dont working((
2020-04-15 7:52 AM
try ones more paste path for Debug folder === nothing, only manualy (((
2020-04-15 7:53 AM
you can it?
2020-04-15 7:53 AM
you have Windows os MacOS?
2020-04-15 8:04 AM
STM32CubeMonitor is tested on Linux, Windows and macOS.
After having double check, I do confirm there is a specific bug to copy/paste on macOS.
We will fix this bug in a future release.
Thanks for reporting this issue.
