2023-11-23 10:43 AM
we're maintaining assembly projects to teach baremetal assembly programming on STM32H750 board.
Project used to compile without and warnings, but lately we're getting new errors.
Project is stripped down to bare assembly and probably something is missing...
This is output :
19:36:14 **** Build of configuration Debug for project stm32h7-asm ****
make -j16 all
arm-none-eabi-gcc -mcpu=cortex-m7 -g3 -DDEBUG -c -list -x assembler-with-cpp -MMD -MP -MF"Core/Startup/startup_stm32h750xbhx.d" -MT"Core/Startup/startup_stm32h750xbhx.o" --specs=nano.specs -mfpu=fpv5-d16 -mfloat-abi=hard -mthumb -o "Core/Startup/startup_stm32h750xbhx.o" "../Core/Startup/startup_stm32h750xbhx.s"
arm-none-eabi-gcc -mcpu=cortex-m7 -g3 -DDEBUG -c -list -x assembler-with-cpp -MMD -MP -MF"Core/Src/Main.d" -MT"Core/Src/Main.o" --specs=nano.specs -mfpu=fpv5-d16 -mfloat-abi=hard -mthumb -o "Core/Src/Main.o" "../Core/Src/Main.s"
arm-none-eabi-gcc -o "stm32h7-asm.elf" @"objects.list" -mcpu=cortex-m7 -T"D:\Delovni\CubeIDE\Sluzba\ORLab-STM32H7\stm32h7-asm\STM32H750XBHX_RAM.ld" --specs=nosys.specs -Wl,-Map="stm32h7-asm.map" -Wl,--cref -Wl,--gc-sections -static --specs=nano.specs -mfpu=fpv5-d16 -mfloat-abi=hard -mthumb
C:/ST/STM32CubeIDE_1.8.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.11.3.rel1.win32_1.1.1.202309131626/tools/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/bin/ld.exe: C:/ST/STM32CubeIDE_1.8.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.11.3.rel1.win32_1.1.1.202309131626/tools/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m+dp/hard\libc_nano.a(libc_a-closer.o): in function `_close_r':
(.text._close_r+0xc): warning: _close is not implemented and will always fail
C:/ST/STM32CubeIDE_1.8.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.11.3.rel1.win32_1.1.1.202309131626/tools/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/bin/ld.exe: C:/ST/STM32CubeIDE_1.8.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.11.3.rel1.win32_1.1.1.202309131626/tools/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m+dp/hard\libc_nano.a(libc_a-lseekr.o): in function `_lseek_r':
(.text._lseek_r+0x10): warning: _lseek is not implemented and will always fail
C:/ST/STM32CubeIDE_1.8.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.11.3.rel1.win32_1.1.1.202309131626/tools/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/bin/ld.exe: C:/ST/STM32CubeIDE_1.8.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.11.3.rel1.win32_1.1.1.202309131626/tools/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m+dp/hard\libc_nano.a(libc_a-readr.o): in function `_read_r':
(.text._read_r+0x10): warning: _read is not implemented and will always fail
C:/ST/STM32CubeIDE_1.8.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.11.3.rel1.win32_1.1.1.202309131626/tools/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/bin/ld.exe: C:/ST/STM32CubeIDE_1.8.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.11.3.rel1.win32_1.1.1.202309131626/tools/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m+dp/hard\libc_nano.a(libc_a-writer.o): in function `_write_r':
(.text._write_r+0x10): warning: _write is not implemented and will always fail
Finished building target: stm32h7-asm.elf
arm-none-eabi-size stm32h7-asm.elf
arm-none-eabi-objdump -h -S stm32h7-asm.elf > "stm32h7-asm.list"
text data bss dec hex filename
900 24 1568 2492 9bc stm32h7-asm.elf
Finished building: default.size.stdout
Finished building: stm32h7-asm.list
19:36:15 Build Failed. 4 errors, 4 warnings. (took 1s.31ms)
Project works, we can upload it and debug it, not sure why it says 4 errors...
Any advice how to fix the project ?
Thanks in advance,
regards.
2023-11-23 11:53 AM - edited 2023-11-23 11:53 AM
Pretty sure this was due to a change in the build tools in a version of STM32CubeIDE. Upgrading to the latest version might fix it. If not, falling back to a previous version will.
Or you can just ignore the warnings.
2023-11-23 10:58 AM
Not really errors, just indicating you have no files or file system support.
Why it might pull a STDIO libraries in might be another matter.
2025-06-25 7:39 PM
i am Upgrading to the latest alrady, but issue still exits.
