2026-01-30 1:53 AM
I am trying to use the gprof editor/viewer within cubeide but it doesn't work, everything just freezes then crashes with no error messages, i also found nothing in the logs
I'm trying to use gprof profiling arm-none-eabi-gprof.exe, i have my code instrumented and got a valid gmon.out file, it is small ~15kb, the file is valid as i can process is manually with gprof.exe and get a textual representation of the profiling data.
However i don't want text output, i want the included viewer in the cubeide, to see in a nice tree view the data, i have the option to open the gmon.out file with the gprof editor but when i do, it asks for the corresponding elf file then after that everything freezes then crash.
What am i doing wrong? Is this expected to work at all? Did anyone use it?
Cube ide1.18 stm32f429 discovery project
2026-01-30 7:32 AM
found the solution for it
in the settings in "Linux Tools Path" you have to enter the path where your arm-none-eabi-gprof.exe is located
for the prefix: arm-none-eabi-
then all works, file is loaded correctly, can be visualized in the gprof viewer, generate graph and so on....
2026-01-30 7:32 AM
