STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
  • 1703 Views
STM32CubeCLT 1.21.0 released
  • 638 Views
Resolved! Where are the header files in Project Explorer?
Where are the header files in Project Explorer? I can open Application/User/main.c and see that it includes main.h, but it's nowhere to be found in the Project Explorer. If i right-click main.h in its includfe statement in main.c and select 'Open Dec...
How to use C++17 standard in STM32CubeIDE
Hi, I'm working on a new Firmware Framework, but I need to use C++17 standard. I used STM32CubeMx tools for generating code and now I'm compiling with C++14.How I can change standard? Instead to compile with C++14 I want to compile using C++17.
Nucleo F413ZH Honeywell MPR sensor STMcube IDE issue
Hi, I am trying to integrate Honeywell MPR pressure sensor (which runs over the SPI) with the Nucleo board using the STM32cube IDE. The library and everything else is working fine with the Arduino IDE environment but deploying things over the STM32cu...
aqeel96 by Associate
  • 2221 Views
Resolved! STM32CubeIDE Versions for Windows 7
Hello, What are the newest versions of STM32CubeIDE and STM32CubeProgrammer that still work under Windows 7?  I have searched high and low but could not find a simple list of versions and host system requirements.  Thank you.
