STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
  • 1703 Views
STM32CubeCLT 1.21.0 released
  • 638 Views
How to set SYSCLOCK to 400 MHz using STM32CubeIDE?
I am using a NUCLEO-H743ZI board. Using STM32CubeMX, I was able to set SYSCLOCK to 400 MHz like so:With STM32CubeIDE, it won't allow me to do the same:What should I be doing here instead?STM32CubeIDE has been really frustrating.
edwin8 by Associate II
  • 2213 Views
STM32F303K8 - CAN bus doing nothing?
Hi there,we are using the STM32F303K8 with the NUCLEO-F303K8 board. I installed the latest STM32 Cube IDE v.1.0.0 and wanted to get the CAN bus working.So after searching for the latest documentation it took a while to figure out the new can bus impl...
MP.17 by Associate II
  • 1745 Views
Is it possible to enable SWV for STM32F030?
I just installed STM32CubeIDE 1.0 version to give it a try. When I tried to enable SWV , i saw it is disabled and can not modifiable. At first, I assumed this is because of some limitation of chip, but with same hardware my other compiler ( Keil ) i...
KG?�l by Associate II
  • 2749 Views
STM32F103ZET error: No device found on target.
After I click DEBUG ,it shows that Error in initializing ST-LINK device.Reason: No device found on target.I think it's not hardware's problem because I can download my program in Keil uvision successfully. and my debug configuration is showed as foll...
RRuan by Associate II
  • 4134 Views
Missing Team integration
I'm comparing against TrueStudio.Missing Subversive (and any version control system). Not a big deal to install from CommunityBigger deal is missing "Team Synchronize" perspective. I can't find a way to enable or download from Eclipse community. This...
