STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
  • 1703 Views
STM32CubeCLT 1.21.0 released
  • 638 Views
Resolved! My code stops working after a while
I'm trying to use DHT22(temperature and humidity sensor). I'm using STM32F030F4 Here is it's datasheet DHT22 DatasheetIn first few seconds. I can get values. But after a while it stucks in here:So i try to implement a timeout to prevent this. I start...
Resolved! What does User Constants in the Device Configuration Tool do?
Hello,I would like to use a global variable in a while loop in my main file. That variable will be set to zero in a interrupt. Unfortunatly the interrupts are created by the device configuration tool in a seperate file. In the device configuration to...
Eden.757 by Associate
  • 2760 Views
stm32cubeIDE bug include folder
Hi,There is no stm32cubeIDE section so I post it here.I found another bug that isn't mentioned on the known issues and I found no bug tracker to post this issueWhen you re-generate code using the integrated cubemx, all included folders (in properties...
bet by Associate II
  • 717 Views
