STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
  • 1703 Views
STM32CubeCLT 1.21.0 released
  • 638 Views
STM32CubeIDE breaks on macOS when upgrading from 1.3.0 to 1.3.1. The application cannot find java after upgrade. (Resolved)
The issue is an erroneous plist: /Applications/STM32CubeIDE.app/Contents/Info.plistThere are missing sections under the Eclipse key.Below is a functional Info.plist, please compare to yours and modify if need be...<?xml version="1.0" encoding="UTF-8"...
jan by Associate II
  • 802 Views
Resolved! Custom linker won't compile
I'm trying to reserve space in RAM for emulated eeprom. I can read and write fine, however when I try to modify the linker it won't compile. The added user section/* Specify the memory areas */ MEMORY { FLASH (rx) : ORIGIN = 0x08000000, LENGT...
MBeau.1 by Associate
  • 2731 Views
Cube IDE debugger cannot stay connected
I am using a Nucleo-F103RB dev board with Cube IDE 1.3.0. I am able to successfully flash the board (which I have tested by making the user LED on the nucleo toggle at different frequencies), but immediately after this is successful, I lose connectio...
WTetl.1 by Associate
  • 2040 Views
