2021-04-19 11:01 PM
I have been trying to flash the SD card of the STM32MP157A-DK1 following the instructions of the ST Wiki, although in this wiki the board used is the DK2. However the flashing process stops after a while and shows the errors that i attach in the pictures. The CubeProgrammer version is the 2.6. After some research i saw that another option could be execute the flashing process from the command shell but i have not been able to do it because it never finds the file to be flashed, despite copying it in the STM32CubeProgrammer\bin folder. Thanks in advance.
2021-04-21 1:42 AM
I assume you are using W10 PC.
Once you have installed latest CubeProgrammer and downloaded/unzipped the starter package on a local folder,
Regards.
2021-04-21 1:42 AM
Regards.
2021-04-22 12:12 AM
Thank you so much! This worked!
