STM32 MPUs Products and hardware related
STM32F439 Evalution Board
We Have bought STM32F439 Evalution Board from STMicroelectronics. In User manual UM1668 specifies the following in Page No.18 and attached for your reference.Note: Ethernet works properly in the default setting (which RX_ER is not connected to PI10 o...
NR.2 by Associate
  • 1209 Views
check host USB0 cfg
STM32WB version 2.9.1.2019050314Linux version 4.15.0.72 64bEclipse version Neon.3 release 4.6.3Java version 11.0.5 2019-10-15Distro Linux Mint 19.2 TinaI am using the discovery stm32mp1-157 and trying to follow the wiki tutorial. I have been able to ...
Beep generator in CS42L51
The CS42L51 used in the STM32MP15-DK2 has a beep generator that can be used to generate tones with selectable frequency and separate volume control.Is this functionality exposed by the CS42L51 ALSA driver? Can this be used from Linux?Thank you,Guill...
USB to TTL communication problem
tty*** is not created when plugging in Prolific Technology, Inc. PL2303 Serial Portlsusb returns: Bus 002 Device 014: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Portbut no tty*** is created and I cannot communicate with the device.Thank ...
MBach.11 by Associate
  • 1091 Views
