2021-02-07 7:23 AM
My app running on M4 uses adc. It starting at kernel boot process using systemd. After some time kernel poweroff vdda and vref while my app is running
[ 14.173564] remoteproc remoteproc0: powering up m4
[ 14.308543] remoteproc remoteproc0: Booting fw image OpenAMP_TTY_echo_CM4.elf, size 2541404
[ 14.361095] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 14.370223] virtio_rpmsg_bus virtio0: creating channel rpmsg-tty-channel addr 0x0
[ 14.389900] mlahb:m4@10000000#vdev0buffer: registered virtio0 (type 7)
[ 14.399505] rpmsg_tty virtio0.rpmsg-tty-channel.-1.0: new channel: 0x400 -> 0x0 : ttyRPMSG0
[ 14.408052] remoteproc remoteproc0: remote processor m4 is now up
[ 14.422284] virtio_rpmsg_bus virtio0: creating channel rpmsg-tty-channel addr 0x1
[ 14.455735] rpmsg_tty virtio0.rpmsg-tty-channel.-1.1: new channel: 0x401 -> 0x1 : ttyRPMSG1
[ 34.411305] vref: disabling
[ 34.413987] vdda: disabling
and my app can't process adc.
So how to prevent disabling vref and vdda?
Thanks,
Alex.
2021-02-24 3:53 AM
Hello Patrick,
My dts files include all defines described your link but vref & vdda disabling by kernel. If I run m4 app after this disabling adc works fine (so app enabled vref and vdda).
PS: I've changed regulator-boot-on to regulator-always-on in dts file. It works.
Thanks,
Alex.
2021-02-16 3:00 AM
https://wiki.st.com/stm32mpu/wiki/How_to_configure_system_resources#ADC_example will probably help you.
Regards.
2021-02-24 3:53 AM
Hello Patrick,
Thanks,
Alex.
2021-03-17 2:00 AM
Sorry for late answer.
Seems regulator-always-on is not needed if you enable the resource manager in the DT as stated in the wiki.
As I understand, this will tell Linux to bind M4 resources to remoteproc status to avoid shutting down VDDA if Cortex-M4 is running.
&m4_rproc {
m4_system_resources {
status = "okay";
};Regards,
Patrick
