2024-08-01 11:10 AM
I have seen an example diagram of STM32MP13X + RTL8363NB in the AN5474 document, how can RCC be implemented in software to provide 125MHz and where can I find the code for that example?
2024-08-05 12:18 AM
Hi @whist
Are you targeting OSTL or BareMetal solution ?
Normally CubeMX might help.
Regards,
Gréogry
2024-08-05 11:37 PM
OSTL,I compiled the system with yocto. Clock problem solved, you ST drive this chip , do you have a driver for it?
2024-08-06 11:56 PM
Hi @whist,
I'm not sure I understand what you mean, could you be more precise?
Regards,
Grégory
2024-08-09 4:45 AM
I want to ask if ST has already tested the driver for this switch chip. I don't have the driver for this chip; can I use a generic network driver instead?
