2024-07-03 8:28 AM
Hello ST,
We would like to use the Extended advertising capabilities of the STM32WB, but could not find the right example for it in the SDK or in the web. Do you have any examples or information/documentation from your side? We would like to advertise at least 255 bytes and if possible more. Please let us know on how to achieve this task?
2024-07-03 10:38 AM - edited 2024-07-03 10:39 AM
Hello @teja_111
I suggest you follow this Wiki for information about the implementation of the Extended advertising capabilities on the STM32WB.
The examples of EXT_Client and EXT_Server are availabe here .and on the Example selector of the CubeMX
Best Regards.
STTwo-32
2024-07-07 11:59 PM
Hello @STTwo-32
Thanks for providing the information. I have gone through the documentation and example provided by you in the above message. The example describes communication between two nucleo boords one acting as a server and other as a client.
But, In our case, we would like to see the extended advertising data in the mobile app namely "STM32 BLE ToolBox" or "Light blue app". We modified the example, but could not able to see any extended data in the mobile app?
Could you please provide a feedback on how to handle this task?
Thanks & Regards
Teja
2024-07-08 12:18 AM
I suggest you connect the Nucleo board with the server program to the application on your Mobile. It should show you the necessary values.
Best Regards.
STTwo-32
2024-07-08 6:05 AM
Thanks for the reply. I can only see the legacy advertising data on my mobile when i connect the server program application to the mobile. But my case is to view the extended advertising data and I am not able to view it in the mobile app.
is it possible, to view the extended advertising data in the mobile? if yes, please let us know, how can we do it?
Best Regards
teja
2024-07-17 12:20 AM
@STTwo-32 do you have any update on this topic?
2024-08-06 9:48 AM
Hello @teja_111
Extended advertising is not supported by all phones since this specification is optional for Mobile devices to be compatible with BLE. Could you please try using different Mobiles and different apps (From ST or others). That should do the Job.
Sorry for my late answer.
Best Regards.
STTwo-32
