2025-08-05 1:19 AM - last edited on 2025-08-05 1:37 AM by Andrew Neil
Split from L072Z LRWAN1: Switch from Class C to A
I also encountered the problem of CLASSC conversion failure. Could you please tell me if you have any solutions at present
2025-08-05 1:33 AM
Using STM32WLE5CCU6 as the main control chip, after switching to CLASSC mode, when the master station sends data, the nodes cannot receive it in time. Only when the receiving window is opened during the upload process can they receive the data. After using an oscilloscope, it was found that the nodes were already in the receiving state. I wonder how to solve this problem.
2025-09-16 11:17 PM
Hello @dannyhui
Have you checked that you are on the right configuration for Class C. If so, what is you SW and HW configuration and what you are saying exactly? Is there any logs or other informations.
Best Regards.
STTwo-32
