2019-03-15 8:23 PM
Hi, guys.
Just downloaded the altium designer design file of P-NUCLEO-WB55.
While I was enjoying the layout, I found that there are many pads, instead of vias, connecting tracks or layers.
I know that they are physically the same, just curious why use pads instead of vias?
I suppose pads are used to connect PCB and footprint, no?
below is an example, captured from the design file.
does anyone know why?
thanks for reading!
Zt.
2019-03-21 2:11 AM
Dears,
There is no specific reason for this mix between Pads and Vias. As you said, physically, with the same spécifications, that's excatly the same result on Gerber files....
Best regards
