2025-11-13 7:55 AM - last edited on 2025-11-13 8:13 AM by Andrew Neil
Hi everyone,
I’m facing an issue with power consumption on my custom PCB that uses the Wio-E5-LE module. According to the datasheet, the module should consume around 2.1 µA in sleep mode, but my board is drawing around 88 µA instead. I’ve double-checked everything and can’t find any other source of leakage.
What i have already checked,
2025-11-13 8:11 AM
Welcome to the forum.
Please see How to write your question to maximize your chances to find a solution for best results.
In particular, please show your schematic.
Some good, clear photos may also help.
@Saarankan wrote:According to the datasheet...
Which datasheet is that - the module's datasheet, or chip datasheet?
Have you contacted Seeed Studio? The module is their product:
https://aftersale.seeedstudio.com/home
https://discord.com/invite/QqMgVwHT3X
https://forum.seeedstudio.com/
2025-11-17 12:46 AM
I am not familiar with the Wio-E5-LE module. However, the µA-figures you mentioned match the numbers in this post:
Maybe this post can give you a hint?
BR
Jonas
