STM32 MCUs Wireless
ctrois by ST Employee
  • 301 Views
Ouadi by ST Employee
  • 4118 Views
Powering Nucleo-WL55JC1 with 1.8V and 3.3V
I wan't to power both cores with 1.8V and, only when using the radio, use 3.3V.I have seen there is a VDDRF pin to power the radio but data sheet says it must be connected to the same supply as VDDMiguel
mromani by Associate
  • 760 Views
STM32WL55CCU6 - I am running LoRaWAN End Node example on custom board. How to make it work without TCXO_ENABLED option?
Hello all,I was developing LoRaWAN applications on MICROCHIP products for many years, recently I switched to STM32 platform. I have developed many applications with STM32L0 + SX1272 combination which worked perfectly. Now I have decided to move to ne...
