STM32 MCUs Wireless
ctrois by ST Employee
  • 301 Views
Ouadi by ST Employee
  • 4118 Views
Resolved! Unable to successfully load Sigfox credentials to STM32WLE5.
Hi There.I've successfully loaded the Sigfox_AT_Slave example to my device and the AT commands work 100%.I then followed the "Personalization and activation" section in document AN5480 to get and flash the Sigfox credentials from ST.When I try to loa...
DThom.5 by Associate
  • 2338 Views
How to migrate from STM32WL55 to STM32WLE5?
I am building LoRaWan code using STM32CubeWL Firmware Package, which is set up for the STM32WL55. My own hardware uses the Seeed LoRa-E5 module, which uses the STM32WLE5. Code built for the STM32WL55 runs on the STM32WLE5, but I thought I should migr...
charles23 by Associate III
  • 2136 Views
