STM32 MCUs Wireless
ctrois by ST Employee
  • 301 Views
Ouadi by ST Employee
  • 4118 Views
Reg: STM32WLE5 MUC delay used for Lora SubGHz_Phy.
Hi Team,I'm using STM32WLE5 MUC for Lora communication (SubGHz_Phy), I want to know is there a way to use Systick instead of timer ?This is because I used RTC to some other use case. kindly share me the way for the same.Thanks,
Resolved! BLE & Thread Concurrent project
Is it possible to create a project in CubeMX for a concurrent BLE & Thread application for the STM32WB55?My attempts so far only allow for either a BLE or a Thread project (not both together).Thanks
romihs by Associate II
  • 2330 Views
Resolved! Pin label defines not generated
When I create a new project using STM32CubeMX with my board (NUCLEO-WL55JC1), neither defines for PIN labels will be generated in main.h nor is there a BSP folder in the Drivers folder with a xxxnucleo.h containing definitions as I have seen in the e...
