STM32 MCUs Wireless
ctrois by ST Employee
  • 301 Views
Ouadi by ST Employee
  • 4118 Views
Resolved! STM32WBA52 programming on custom board
I am trying to detect my stm32wba52cg bare chip with my developed custom PCB board with onboard stlink as external programmer from a discoveryboard but its showing this msg-Can not connect to target!Please select "Connect Under Reset" mode from Targe...
Resolved! STM32WB55 Zigbee name
Hi together,I am working with the STM32WB55 and connecting it with different configurations to Homeassistant via Zigbee2mqtt.The Zigbee2mqtt auto generates a config file with the available endpoints etc., that looks like this:const definition = { ...
vh789 by Associate III
  • 8281 Views
  • 10 replies
Product enquiry
Hi ST Experts, We have a BLE project based on the STM32L476 and HM11 BLE and we are looking to minimize the component count and shrink the board size. We want to replace the STM32L476 with a BLE and MCU single chip solution and we are considering the...
PN_ by Associate II
  • 2813 Views
  • 8 kudos
STM32wb55 Nucleo Zigbee zbinit request id
Hi, I'm currently just for learning experience trying to learn about Zigbee and how it works through IPCC. This boils down to a program that I wrote that tries to setup the Zigbee stack.I've OnOff_Server_Coord example as a guidance on how it should b...
andyy by Associate II
  • 1843 Views
Zigbee Table Routing
Hi,I have many routers for sending data to the coordinator. I want to use table routing. How can I implement this? And how does table routing work? What happens behind the scenes?Best Regards,
Ndemir by Associate II
  • 3980 Views
Resolved! nucleo wb55rg BLE Not Working
Hello Community,Greetings of the day.I'm using the Nucleo WB55RG board. I'm trying to initialize and connect the wb55rg BLE with my mobile app.So, I'm following the stm32wb getting started video series, video part-12b. (video link - https://youtu.be/...
OS_Er by Associate II
  • 3718 Views
  • 4 kudos
Resolved! B-WB1M-WPAN1: DMA2 not available
Colleagues.The STM32Cube_FW_WB_V1.20.0 library for STM32Cube_MX version 6.12 allows me to create DMA2 channels for B-WB1M-WPAN1. However, the startup_stm32wb1mxx_cm4.s and stm32wb1mxx.h files do not contain DMA2 interrupt vectors. Error[Pe020]: ident...
