2019-04-12 2:17 PM
I am using B-L072Z-LRWAN1 and AT_Slave project from I-Cube-LRWAN. Can Anyone help me with the setup to measure current consumption like jumper position and across which pins to measure current?
Thank You
2019-04-12 3:59 PM
The manual describes JP1, JP2 and JP3 and the related solder bridges SB19, SB14 and SB17, start with those perhaps?
I think @Andrew Neil identified a couple of components in the battery path that could be removed also.
