2020-05-28 8:01 AM
Using TouchGFX Designer 4.13.0 with my Discovery Kit STM32H7B3 I have problem during Generate Code - Run Target and Run Simulator: it takes 5 to 10 minutes to generate Assets or starting simulator.
I have a Win10 Pro 64 Bit, 32GB Ram, Intel i7 vPro 8th Gen, SSD HDD.
As I saw in other post, I also disabled Avira Antivirus but without success.
Could you please help me?
Thanks
2020-08-17 5:36 AM
Did you solve your problem ?
/Alexandre
2020-08-26 10:37 PM
I have the same issue! Really,really slow !
2020-08-26 11:14 PM
Could you try installing TouchGFX 4.14 and see if it behaves the same ?
Is it the same if you choose another Application Template ?
/Alexandre
2020-08-27 11:56 PM
Does the same thing happen if you compile using the TouchGFX Environment?
make -f simulator/gcc/Makefile
