2021-02-26 7:44 AM
Hi
After compiling, I get an error: BitmapDatabase.hpp in the TouchGFXConfiguration.cpp file.
I checked three times. It repeats itself.
Andrzej
2021-03-01 2:26 AM
2021-02-28 11:57 PM
How did you start your project ? Did you use the application template for the STM32F746 disco board available in TouchGFX Designer ? Did you create your own UI or did you use a UI template ?
What tollchain/IDE are you using ?
Could you share a screenshot of your issue ?
/Romain
2021-03-01 12:52 AM
I did it according to:
https://www.youtube.com/watch?v=12KXreXaLp0&t=3s
If this is the cause of the error, how to change?
Andrzej
2021-03-01 2:26 AM
2021-03-01 2:29 AM
When I open a program from an older version of STM32CubeIDE and TouchGFX it works.
Andrzej
2021-03-02 2:17 PM
Once again I downloaded the latest versions and installed. It works.
Thank you.
Andrzej
