2023-03-14 11:22 PM
2023-03-15 1:24 PM
Hello lchac.1,
Could you tell us a bit about your configuration? Is your project based on a TBS (TouchGFX board setup) or is it a custom board? Whis version of TouchGFX do you use? Which compiler do use?
To me it looks like an issue related to your memory mapping. How did you define your memory regions in your linker script?
/Osman
2023-03-15 2:04 PM
>> can anyone explain this
Based on your presentation of the facts, no.
The question doesn't have to fit entirely into the Title/Summary, use the body of the question, you can edit posts, and provide more detail, attach images or files.
If this just happened, I'd supposed you added multiple instances of the file.
