Links in TouchGFX LineProgress page return "Page Not Found"
JMors.1
Associate III
When looking at the TouchGFX LineProgress page under UI Development->UI Components, clicking on a link in the description returns a "Page Not Found" Error.
Page in question:
https://support.touchgfx.com/docs/development/ui-development/ui-components/progress-indicators/line-progress/
For example, under User Code, there is a link labeled "beginning of this article", but when clicking on this, a "Page Not Found" error is seen.
https://support.touchgfx.com/docs/development/ui-development/ui-components/progress-indicators/line-progress/line-progress
NOTE: 'line-progress' is in the link twice. If I remove the second 'line-progress', the page displays as expected.
5 REPLIES 5
Alexandre RENOUX
Principal
Thank you very much for the feedback. Where exactly did you click to have this wrong url ?
/Alexandre
Romain DIELEMAN
I have been able to replicate it. This has been noticed, thank you for reporting this.
/Romain
Moving around the documentation through the menu on the left hand side of the page will remove that issue for now.
JMors.1
Associate III
Okay, that will work.
Another TouchGFX page that has issues is the main TouchGFX Documentation page. If accessing this page via the TouchGFX Help Center page via the "support.touchgfx.com" link, clicking on the links listed under "About this Documentation" results in "Page Not Found"
Ex:
From here:
https://touchgfx.zendesk.com/hc/en-us/articles/205074561-Connecting-the-UI-to-your-system
To here:
https://support.touchgfx.com/docs/introduction/welcome/
Clicking on "Welcome" in the left menu area, or removing "welcome" from the resulting page seems to product a set of links that work.
However, refreshing the screen results in bad links again under "About this Documentation".
Page listed after clicking on "Introduction" and results in "Page Not Found":
https://support.touchgfx.com/docs/introduction/welcome/what-is-touchgfx
This seems to work:
https://support.touchgfx.com/docs/introduction/what-is-touchgfx
Also, on the TouchGFX "Backend Communication", there is a link to MVP listed under "The Model Class" in the "Further reading" area that results in a "Page Not Found" error.
https://support.touchgfx.com/docs/development/ui-development/touchgfx-engine-features/backend-communication/
Alexandre RENOUX
Principal
Thank you again. This has been taken into account and we will try to fix this as soon as possible.
EDIT: This should be fixed for the next release, normally planned in two weeks
/Alexandre
