2020-09-09 3:41 AM
I have a very simple question and I hope there is some simple answer.
After creating translations in TouchGFX, we noticed that numbers can be display either using decimal points ($12,333,444.00) or using decimal commas (12.333.444,00€).
When I change the language from say English to French, how do I change the values displayed to differentiate decimal point and decimal comma?
2020-09-09 5:38 AM
Sorry but I'm not sure I understand what you are trying to say.
You want to have a number with commas in one language and with dots in another language, right ?
Also, if you could enclose a small TouchGFX example, this would be helpful.
/Alexandre
2020-09-09 5:38 AM
/Alexandre
2020-09-09 5:59 AM
Hi Alexandre, that is exactly what I am trying to say.
You can check out this Wikipedia article which explains the concept even further https://en.wikipedia.org/wiki/Decimal_separator#Countries_using_decimal_comma
Basically depending on the language, the numeric output needs to look different.
I will enclose a minimal example soon. But it should not be needed for this - this is very generic.
2020-09-09 6:57 AM
Change of plans for us, we won't use this functionality. Still it might be an interesting feature for others.
