STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
ILI9881C DSI on STM32H747
I have a third party screen that is driven by an ILI9881C and I am having a lot of trouble getting TouchGFX up and running.I first started running DSIHost in Adapted Command mode with TE Pin and I could configure the driver's registers as necessary a...
Iris-DM by Associate III
  • 2389 Views
Display Riverdi RVT50HQSNWC01-B
Good morning,we are working on a project using a 5 inch display (RVT50HQSNWC01-B) in the TouchGFX Designer environment. Simulation, code generation and code download to the MCU works.Problems arise when moving to STM32CubeIDE. In this environment, ca...
1bit mode white color bug
Hi, i discovered wierd behavior for touchgfx when using 1bit mode (BW or BW_RLE). Issue happens when you place black color on white one, then in editor everything looks normal but in simulator and on the board the white color overlays the black one. ...
