STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
STemWin issues during linkage?
Posted on July 27, 2017 at 09:49Hi STM32 communityI'm tring to use STemWin in my project. I use IDE eclipse running on windows.I've created a project with STM32cubeMX V1.0 version 4.22 (STM32Cube_FW_F7_V1.7.0 firmware ).After generating the project ...
stm32f429 graphic LCD
Posted on September 05, 2017 at 13:37Hi everyone.I have stm32f429-DISC0 board and I wanted to use graphic LCD. I found the CMSIS workshop series and step by step I did everything as said on the video. But unfortunately after 3th video nothing worked...
mk61 by Associate II
  • 1225 Views
Resolved! JPEG Compression Example
Posted on August 29, 2017 at 12:09I have an array of luminance representing a picture in grayscale. Data are captured using DCMI. I need  to compress these data using JPEG unit available in F7 series, but I can't find any application note describing...
How to use STemWin on IAR 6.40?
Posted on August 28, 2017 at 18:32Hello!I am using STM32437I-EVAL on IAR 6.40 IDE.I am trying to load an example of a project using STemWin library, but when I import the project on IAR, it pops up a dialog box saying 'Broken options were detected o...
Stemwin GUI not working for external SDRAM
Posted on August 21, 2017 at 09:50I have linked STemWin library. My project uses external SDRAMWhen I display some progressbar or treeview or graph using internal RAM, value of progress is displayed correctlly (ex. 50%). Also treeview and graph is d...
Resolved! Using DCMI in interlaced scans
Posted on August 10, 2017 at 08:47I am working on an application which requires interfacing an analog camera. I have choosed TI TVP5150AM1 to decode analog video to YCrCb 4:2:2 format and the scan format will be interlaced. As it has been mention he...
STemWin listview problem
Posted on July 19, 2017 at 10:36Hello,I have some trouble with my listview widget. 1. I can change the column width 'manually' - I mean by touch. Is there a possibility to set it fixed width? I noticed that when I change the width by this way the li...
M Ryb by Associate
  • 1303 Views
CubeMX 4.22.0 bug for DMA2D config
Posted on July 31, 2017 at 19:58It is DMA2D config, generated CubeMX for Keil.hdma2d.Instance = DMA2D; hdma2d.Init.Mode = DMA2D_M2M; hdma2d.Init.ColorMode = DMA2D_OUTPUT_ARGB8888; hdma2d.Init.OutputOffset = 0; hdma2d.LayerCfg[1].InputOffset = 0; hdm...
