STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
SysTick stopped firing when added TouchGFX
Hi,I am using STM32F778AI with FMC SDRAM and MIPI-DSI for screen.Before adding touchgfx SDRAM, DSI , Systick worked. After adding touchgfx it stopped working and stuck on HAL_Delay because Systick don't enter to interrupt.Any help ?David
davidra7 by Associate II
  • 3359 Views
Waveform Widget
I’m creating a waveform widget in TouchGFX, but unsure how best to loop the waveform back to zero at the end because there are three frame buffers so you have to invalidate over an area three times or you get flickering . How would you handle looping...
BMara.1 by Associate II
  • 2092 Views
Availability of the library's core source files
It appears that not all declared methods are implemented in the provided header and source files. Some methods like HAL::flushFrameBuffer, are apparently implemented only in the core static libraries. Is there any plan to release the source code of t...
ALiar.1 by Associate
  • 1101 Views
KeyBoard Example
Hello.Run Target Keyboard Example with TouchGFXIn the case of F746G Discovery, it is displayed normally.In the case of F769I Discovery, the keyboard is displayed small.Is there a problem with TouchGFX?Thank you.
Ebun.1 by Senior
  • 1109 Views
Graphics glitches on STM32F429I-DISCO
Hello,I'm trying to setup a simple example on my STM32F429I-discovery board, but i'm experiencing issues with some graphics (images).I had setup CubeMX using this guide : https://touchgfx.zendesk.com/hc/en-us/articles/360021620431-Configuring-STM32F4...
