2019-12-16 7:23 AM
I have searched around this forum and the internet, without finding a solution. The Alignment setting in the designer does not help. I want the text (5 digit integer) to be right justified with no leading zeroes. Latest version of ToughGFX and Cube. Thanks
2019-12-16 1:23 PM
FIXED: the fix was to make sure the text area is large enough for the largest number, select right justify/align in the designer, and do NOT resize the area before the invalidate.
2019-12-16 1:23 PM
