STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
Getting Frame by frame video output.
Hi Community,I have got the video output , using video widget in Touch GFX (v4.19.1). But video is playing frame by frame as attached in video. Anyone is having idea about the solution for the same?IDE : STM32CubeIDE (v1.10.0).Designer :Touch GFX Des...
Vins by Senior
  • 2234 Views
Why is the text area not getting resized?
I am able to display the P_soc properly but when I tries to print (P_temp_h)*0.1 if it is 4 digit( i.e 2 digit before decimal and 1 digit after decimal and decimal point) then I could display the data properly. But If it is 5 digit then the function ...
KMod3 by Associate II
  • 1714 Views
Resolved! Screen suddenly started flickering every 12 seconds at 350MHz, but is not flickering at 480MHz. Too many drawables?
The screen of my H750B-DK board is weirdly flickering every 12 seconds when the system clock is set to 350MHz. Previously I was at 400MHz when the issue first appeared and the flicker happened about every 10 seconds. At 480Mhz (max) the issue seems t...
GHeller by Associate III
  • 5349 Views
TouchGFX with STM32H743 custom board
When I tested TouchGFX and CubeMX with the STM32H735 discovery kit, it took me 1 hour to develop my UI and validate it (great!)I designed a custom board with a STM32H743ZI and I have been trying to generate a proper project with CubeMX and TouchGFXFi...
