STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
After update of Touch GFX, Colors on the display (Hardware) are not the same than on the simulator. | Alpha factor isn't working (Opacity)
After updating my project, from 4.15.0 to 4.18.1 the colors displayed on the display are not the same that those on the simulator.The simulator works fine colors are correct.Moreover I observed something strange:If I set the color depth at 16 bpp : C...
Help to fix a TouchGFX custom board project
MCU : STM32H743ZISTM32CubeIDE 1.10.1TouchGFX 4.18.1I created a stm32h743 project with cubeMX and created a simple red screen as in this video https://www.youtube.com/watch?v=SRQD8JMeg_k&t=3034sI added the fix in this topic https://community.st.com/s/...
TouchGFX cube_programmer.mk project File template
TouchGFX projects has a cube_programmer.mk in each project folder.I have installed my CubeProgrammer in a different location to the default location in the cube_programmer.mk. I was wondering if the cube_programmer.mk is created on each project creat...
Where is Code editor in TouchGFX also where is output window to know errors generated? Run failed for me, where to check for errors?
I am new to TouchGFX. I am working on STM32 controller based project. In that TFT LCD screen is one of the peripherals. I want to create screens using TouchGFX so that i can set value on screen and run timer according to the value entered on screen, ...
ABeck.1 by Associate II
  • 10198 Views
  • 25 replies
