2026-02-16 10:22 PM
Hi everyone,
I’m using the B‑U585I‑IOT02A development board for an IoT project. The onboard STSAFE‑A110 secure element comes pre‑provisioned with a default key and certificate, but for my application I need to:
I couldn’t find a clear step‑by‑step guide for:
Is there any official documentation, example project, or provisioning tool that explains how to do this on the B‑U585I‑IOT02A?
Any guidance or links would be greatly appreciated.
Thank you!
2026-03-24 4:33 AM
Hi @macar,
Generally with Secure Element, this is complex to inject a private key, therefore the Secure Element offer a key generation mechanism which is the case for STSAFE-A110.
On the evaluation part the STSAFE-A110, you have pre load private key on slot 0 which can't be renewed.
So, you can only generate a new key pair on the private slot 1.
What you can also do is to generate PKCS#10 CSR with the private key 0 or a newly generated private key on slot 1 to enroll to your PKI to get your own certificates.
Then you can use the STSAFE-A110 memory region to store your own certificate.
As the STSAFE-A is a companion chip a MCU, this is out of the scope of the STM32 programming tools. You need to use the STSAFE-A Middleware in order to manage the STSAFE-A for key generation and memory region read/update.
If you need more private key slot, I would recommend to look at the STSAFE-A120.
You can also find some code example that can help to generate CSR with MbedTLS in this thread
Best Regards,
Benjamin
