STM32 MCUs Security
Readout protection only for Flash, not EEPROM possible?
Posted on January 24, 2018 at 15:19Hi,we are facing troubles with the readout Protection on the STM32L0: when you secure the chip and then want to do a firmware update, the Settings and serial numbers in EEPROM also are erased. Can we somehow protec...
STM32F407 and CRC
Posted on January 19, 2018 at 11:55Hello friends.I created CRC calculator, but I don't know, how to compare results.My input data:uint32_t data[16] = {       0x1234, 0x456, 0x78, 0x09,       0x10, 0x100, 0x1000, 0x01,       0x54, 0x35, 0x98, 0x2432,...
STM32F103 CRC32 of uint8_t buffer
Posted on January 10, 2018 at 14:51 Hi there, I wrote a serial protocol to exchange data between MCU and a PC. This protocol provides a checksum to verify data integrity. At the moment I use a simple sum of each byte but I think that the...
Fede Rico by Associate III
  • 2228 Views
crypto lib - VFP error
Posted on January 09, 2018 at 14:27HelloI would like to use the crypto lib with gcc (eclipse/ system workbench).The compiler returns this:error: xxx.elf uses VFP register arguments, libSTM32CryptographicV3.0.0_CM4_GCC_ot.a(crypto.o) does not.I'm not...
tarzan2 by Senior
  • 1185 Views
STM32L4 Read Protected when flashing
Posted on December 19, 2017 at 09:21Good morning,I'm working in my custom application based on STM32L4.Sometimes, a problem appears when trying to flash the device: If I try to flash it with Keil and Ulink2 interface, a message suddenly appears when...
SPI Broken Communication
Posted on January 31, 2016 at 10:19Hello, I am currently evaluating the EVALSTPM34 Smart Metering IC so that a decision can be made about including it in a smart home management system. Here is the STPM34 IC datasheet for reference: https://my.st.co...
ahmad2 by Associate II
  • 3121 Views
STM32F429ZIT Read out protection RDP=2 long time
Posted on November 22, 2017 at 14:23Hello all,Our product is being programmed on test bench and after that it is locked setting the readout protection to level 2 (RDP level 2).My question is - is it normal for this process to take about 3 minutes?Ar...
