STM32 MCUs Security
Secure Boot on STM32L475 Discovery IoT kit
Posted on March 17, 2018 at 20:14Hi I want to PORT X-CUBE-SBSFU on to STM32L475 Discovery IoT kit.I want to know what are the initial steps i need to do for PORTING SBSFU on any nucleo Board.Thanks Phanirajkiran#iot-node #device-security #secure-boo...
Secure Boot On STM32L4RQX
Posted on March 12, 2018 at 07:21Hi How do i proceed to write a &sharpsecure boot on STM32L4RXX, with out &sharpHW Crypto. I need to make it by Software later i want to use the HW Crypto provided. Thanks.,Phani#secure-boot
Enable and disable write protection stm32l4
Posted on March 05, 2018 at 19:18I am new to stm32 micro-controller.  I have a question regards to how to enable and disable write protection with stm32l4 chip.  My goal is first I will check if user application is write protected or not, if it is t...
Use stm32 crc to compare DS18B20 crc
Posted on February 25, 2018 at 11:10Hello friend,I have DS18B20. And I read his uniq ID with CRC.And I know, that STM has crc calculator. So I read data from DS18B20: 0xab 0x1 0x4b 0x46 0x7f 0xff 0x5 0x10 : CRC 0x92And I use internal calculator on ...
STM32-CRYP-LIB download problem
Posted on February 14, 2018 at 18:39Hy.I would like to download the crypto library. When I click the request software button, a form shows up. I fill the form correctly, but nothing happens, I cannot download the software.I really need the library. ...
CRC32 calculation in C#
Posted on August 04, 2014 at 10:47 Hi, I created a C# class which calculates the CRC32 checksum exactly like the STM This may be useful to others: using System; using System.Collections.Generic; using System.Linq; using ...
RSA CRYPTO LIBRARY
Posted on February 01, 2018 at 14:46Hi.I'm using an RSA cryptographic library and I have a big issue with the verification process.ST crypto library for RSA has a 'standard' module, message, key pairs and signatures in its main program.I need to use...
Trouble with the CRC unit on STM32F407
Posted on January 17, 2018 at 10:52Hello everyoneI have some trouble with the CRC unit on my STM32F407 MCU.Before each time I am going to use it to calculate a checksum, I reset it and after doing so I double check that the CRC data register (CRC_DR...
Nils B by Associate II
  • 5992 Views
  • 11 replies
X-CUBE-CRYPTOLIB AES-CCM optimization
Posted on January 26, 2018 at 09:27Hi,I'm using AES CCM algorithm from X-CUBE-CRYPTOLIB (STM32AccHwCryptoV3.1.0_L4_KEIL_otslsm1elfspf.lib) in sensitive real time system and unfortunelaty it does not fit our time requirement. We would like to investi...
