2018-08-17 2:09 AM
1.Uncommenting one line in service_asset.c still can't work.
Request a token from Amazon website. It shows token "ANeQCyBUgoyAFxrpfsUJ" in browser.
But my STM32F769I shows below messages: Always can't pass Amazon ATS certificates.
Network : ssl_tls.c:4591 : c04337f4: x509_verify_cert() returned -9984 (-0x2700)
TLS certification error, check the Root CA : EVT_TLS_CERT_VERIFY_FAILED(0)
Open a TLS Connection : EVT_OPEN_TLS(0)
Debug : avs_token_imp.c:462 : could not get token from amazon with code ANeQCyBUgoyAFxrpfsUJ
2.Create new project in developer.amazon.com/avs/, and get new client_id, client_secret, project_id, renew these information has the same error.
3.Check CA in default_amazon_root_ca_raw.c, ROOT CA are the same as listed in https://www.amazontrust.com/repository/, But no "Cross Certificates" and no "Other CAs"
in f/w.
What should I do to fix this issue?
2018-08-29 11:54 PM
The detail error log is as below:(I reneamed part of clientId/clientSecret)
Sdk : Version v1.1.1
App : Version v1.1.1
Debug : service_persistent_storage.c:246 : Persistent: Write Item in Flash
Debug : platform_adapt.c:226 : going to overwrite flash memory
Debug : platform_adapt.c:273 : Persistent: Refresh OK
Debug : service_persistent_storage.c:310 : Read Private config
Debug : service_persistent_storage.c:321 : Flash Store empty
Debug : avs_lwip_network_imp.c:164 : Start the Network ...
Debug : avs_lwip_tls_imp.c:196 : Seeding the random number generator.
Debug : service_persistent_storage.c:227 : Read CA Root
**** Instance *** clientId : "amzn1.application-oa2-client.042288f4357e41c4babb533b67bxxxxx" clientSecret : "a4288cc28f02c4e680e1f545935d84dda7124a7f18ca697af4985e688f0yyyyy" productId : "my_device4" serialNumber : "S/N_2818085" macAddr : { 0xE0,0xA0,0x25,0x00,0x2B,0x80 } hostName : "STVS4A Application" used_dhcp : 1 use_mdns_responder : 1 ipV4_host_addr : "***.***.***.***" ipV4_subnet_msk : "***.***.***.***" ipV4_default_gatway : "***.***.***.***" ipV4_primary_dns : "8.8.8.8" ipV4_secondary_dns : "8.8.4.4" urlNtpServer : "0.fr.pool.ntp.org" urlEndPoint : "avs-alexa-na.amazon.com" redirectUri : "http://stvs4a/grant_me" cpuID : "STM32F769I cut 1.1" toolChainID : "GCC" profile : 2:AVS_PROFILE_NEAR_FIELD initiator : 2:AVS_INITIATOR_TAP_TO_TALK portingAudioName : "bsp-audio" netSupportName : "LWIP_eth" alexaKeyWord : "ALEXA" synthesizerSampleRate : 24000 synthesizerSampleChannels : 2 useAuxAudio : 1 auxAudioSampleRate : 16000 auxAudioSampleChannels : 1 recognizerSampleRate : 16000 eventCB : 0x08014BED eventCB_Cookie : 0x00000000 persistentCB : 0x08014BE9 memDTCMSize : 128 memPRAMSize : 147 memNCACHEDSize : 0 **** Audio *** audioInLatency : 0 audioOutLatency : 0 audioMp3Latency : 0 initVolume : 60 freqenceOut : 48000 buffSizeOut : 0.00 freqenceIn : 16000 buffSizeIn : 0.00 chOut : 2 chIn : 1 platform.numConfig : 0 platform.numProfile : 0************ Start ***************
14:32:32 : Mem DTCM 128 KB -> 100.0%
10:44:16 : Mem PRAM 147 KB -> 100.0%
10:44:16 : Mem HEAP 3959 KB -> 96.7%
Debug : avs_lwip_network_imp.c:103 : IpAdress = 192.168.101.105
11:35:28 : Recognizer task starts : EVT_AUDIO_RECOGNIZER_TASK_START(0)
13:07:12 : Synthesizer task starts : EVT_AUDIO_SYNTHESIZER_TASK_START(0)
15:55:44 : State task starts : EVT_STATE_TASK_START(0)
Debug : avs_state_imp.c:412 : Enter Start HTTP2
Debug : avs_state_imp.c:428 : Leave Start HTTP2
00:00:00 : Connection task starts : EVT_CONNECTION_TASK_START(0)
21:17:52 : Reset Http2 : EVT_RESET_HTTP(0)
Debug : avs_token_imp.c:138 : Wait for a token available
15:55:44 : MP3 task starts : EVT_MP3_TASK_START(0)
04:05:17 : Network time synchronized : EVT_SYNC_TIME(1)
04:05:17 : Refresh Token task starts : EVT_REFRESH_TOKEN_TASK_START(0)
Debug : service_persistent_storage.c:185 : Persistent: Looking from token in Flash
Debug : service_persistent_storage.c:189 : Flash doesn't contain a valid token yet
Warning : avs_token_imp.c:517 : RefreshToken is null... can't get a token from a previous session from persistant memory
Debug : avs_token_imp.c:460 : could not get token from amazon with code
04:05:17 : Read persistent token : EVT_READ_TOKEN(0)
04:05:17 : Wait a token : EVT_WAIT_TOKEN(0)
Debug : service_authentication.c:291 : Auth Server Send :
HTTP/1.1 302 Found
Location: https://www.amazon.com/ap/o...{ "alexa:all": { "productID": "my_device4", "productInstanceAttributes": { "deviceSerialNumber": "S/N_2818085" } } }&response_type=code&redirect_uri=http://stvs4a/grant_me&state=stm32F7_RqGC Content-type: text/html
04:05:27 : Wait a token : EVT_WAIT_TOKEN(0)
04:05:57 : Token renew via the web page : EVT_RENEW_ACCESS_TOKEN(0)
Debug : avs_lwip_tls_imp.c:293 : Connecting to tcp/api.amazon.com/443...
04:05:57 : Wait a token : EVT_WAIT_TOKEN(0)
Debug : avs_lwip_tls_imp.c:304 : Setting up the SSL/TLS structure
Debug : avs_lwip_tls_imp.c:347 : Performing the SSL/TLS handshake
Network : ssl_tls.c:4587 : 0xc043681c: x509_verify_cert() returned -9984 (-0x2700)
Debug : 04:05:58 : TLS certification error, check the Root CA : EVT_TLS_CERT_VERIFY_FAILED(0)
04:05:58 : Open a TLS Connection : EVT_OPEN_TLS(0)
avs_token_imp.c:460 : could not get token from amazon with code ANkbcVrAdaJvYuFpLhGc
Any suggestion to fix this problem is appreciated!
2018-08-29 11:59 PM
My Sequence is: (have step3 or haven't step3 results the same error)
1.enable the new Amazon ATS certificates by uncommenting this line in service_asset.c
{"default_amazon_root_ca", default_amazon_root_ca, sizeof(default_amazon_root_ca)},
2.Enable Messages in avs_base,h
AVS_TRACE_LVL_DEFAULT = (AVS_TRACE_LVL_ALL)
3.Create a Project in developer.amazon.com, update MY_CLIENT_ID, MY_CLIENT_SECRET_ID, MY_CLIENT_PRODUCT_ID values from "Security Profile > Web" page
Add "http://stvs4a/grant_me" in "Allowed return URLs"
4.Use trueStudio build code, select \Projects\STM32F769I-Discovery\Applications\STVS4A\SW4STM32\STVS4A_BSP_LWIP
Binary file outputs: STM32_AVSdemo_F769.elf
5.Use STM32CubeProgramer:
5-1.Connect Device
5-2.Option:Unlocked DBANK
5-3.Select STM32_AVSdemo_F769.elf, set Verify programming.
5-4.Select Available external loaders:MX25L512G_STM32F769I_DISCO
5-5.Full chip erase
5-6.start programming
6.Plug Network from RJ45, Hardware Reset Device
7.Open PC's browser, enter Device's local ip, log in Amazon, redirects to a token url. rename with the local ip in front of the url
8.Browser shows:Got the Alexa access token : xxxxxxx...
But Message shows
"Network : ssl_tls.c:4587 : 0xc0436874: x509_verify_cert() returned -9984 (-0x2700)"
"TLS certification error, check the Root CA"
Error : avs_state_imp.c:450 : Start time-out > 120 secs
2018-08-30 1:36 AM
don't change service_asset.c for the moment and it will connect.
This piece of code was written, based on Amazon message telling that the connection way would be updated mid June. The connection part itself was tested on a test server, but the full use case could not be executed at that time.
Currently the legacy way still works.
We'll work on this evolution and make it work for next release.
Emmanuel
2018-08-30 3:26 AM
I remove step1.
A Token is already available
But still get another Error as below:
Debug : avs_http2_imp.c:215 : http2ClientConnect FAILED with error : 1 : Retry
The LCD always shows: Resolving Amazon...
Firmware returns error (HTTP2_STATUS_FAILURE) in
Http2Status avs_porting_http2_client_connect(AVS_instance_handle * pHandle)
>> Http2Status err = http2ClientConnect(pHandle->hHttpClient, &serverAddr, sizeof(serverAddr));
Error : avs_lwip_tls_imp.c:359 : mbedtls_ssl_handshake FAILED : -0x4c
09:55:56 : Open a TLS Connection : EVT_OPEN_TLS(0)
Debug : avs_token_imp.c:460 : could not get token from amazon with code ANzqtPBvLEoybtUstaAP
09:56:07 : Wait a token : EVT_WAIT_TOKEN(0)
Network : ssl_tls.c:4587 : 0xc04367ac: x509_verify_cert() returned -9984 (-0x2700)
Debug : avs_lwip_tls_imp.c:368 : Verifying peer X.509 certificate
Debug : avs_lwip_tls_imp.c:375 : mbedtls_ssl_get_verify_result FAILED
! The certificate is not correctly signed by the trusted CA
Debug : avs_token_imp.c:254 : Token: Header
POST /auth/o2/token HTTP/1.1
Host: api.amazon.com
Content-Type: application/x-www-form-urlencoded;charset=UTF-8
Content-Length: 242
09:56:11 : Open a TLS Connection : EVT_OPEN_TLS(1)
Debug : avs_token_imp.c:256 : Token: Body
grant_type=authorization_code&code=ANzqtPBvLEoybtUstaAP&client_id=amzn1.application-oa2-client.042288f4357e41c4babb533b67bxxxxx&client_secret=a4288cc28f02c4e680e1f545935d84dda7124a7f18ca697af4985e688f0yyyyy&redirect_uri=http://stvs4a/grant_meDebug : avs_token_imp.c:138 : Wait for a token available
Debug : avs_token_imp.c:301 : Token: response header
HTTP/1.1 200 OK
Server: Server
Date: Thu, 30 Aug 2018 09:56:12 GMT
Content-Type: application/json;charset=UTF-8
Content-Length: 1212
Connection: keep-alive
x-amzn-RequestId: ed8754c0-ac3a-11e8-82a8-11a3f5ccf6d0
X-Amz-Date: Thu, 30 Aug 2018 09:56:12 GMT
Cache-Control: no-cache, no-store, must-revalidate
Pragma: no-cache
Vary: Accept-Encoding,User-Agent
Debug : avs_token_imp.c:323 : Token: Response body
{ "access_token":"Atza|IwEBIN1G0om_AEQXo4a9XwdOTXwU2_GYKgK2ADTnBkwtwSr7Y6XumcBH7j4HXh_CxEPll0X6YsFPmqSTrjCPbbHjmMJaYn9C2PnBULQKPOV7TasQIOxggsIbXSmKWwFxFRMl9pxg_jaLUN_ooMaJqsNyZhWnHcTt2AODL5bTF3dbykkbsf900PaFNdUFOboHg0RkRgzvY-oaPrtMrZ4zh8jrjb9OssbrT5TMAzZdZfcxDiHFCpqs9I9qoKeX8NJr6YiZgKdnPnRs7gHowkALEHZQXI9Fl_86hoebCpKhRIGpjzwJR1XJp3HzX8PVEuvsvt50ttd7Y6pZ9Tknp8yyLpXLMqqmSceu4Ey6cxbds6jQ4d8xoxQwsb3LpVxOVfwTXrP2HnGoCVBW68QIwMOHgxXhWWRzbQc6iv-TVLh8dKY3_kPZZuUkEnkfuqRNHSYIattW-DapI3i8RTK8CUQ8Ewye7hEMJz_-CcimbJ--v7r9DUtyw22ojnqNeO-QgzTrbCUe2JJcCaiFjfZdRplE0VOTpk127r1mkWs7wld3pXyxzHddGw", "refresh_token":"Atzr|IwEBIBhatC_XrM6UZKORNxc14CsHy0fF3AuJmLb5120JEUivHgQQb6pZt47wE17RwZQVBL6NTFNwo0mIH99qad7TIVmojCOkqkuMOV1hUSsvi17Pkay7PFqgEFDr8sRcupcJfu2UZ4L7j31GEjV50skqyLZTPzES_n8UCGhNHWFEFO7gM5d-zkqSrREzsdTM20ew3MVNUdNzd4i340BWDBfss9EXyq7_kIdcugWXUfifinGXhg4pmx_3SG7fvb4EAl7ys5LDanKayQq1LlvfNhUmAyRXuT6CPrqjj3AG3mjC6LtbcqyiCAWDVGt3iBMyPhMEbkuRaW0kzvvXBJotLHZO4fzDS-JvZd7ClbekYLVAJrM0QGODfjGRoiDmS7nb7YkPjTU7fXv-D5jBDa9nUYUrGbZ_qfxIOWDr1jDnZLDiAaCyKaZaTOjC2ki9a9hiV2tPyc3zyAWGr0_FJ2smp5LgvRbazdbIh5IdquCuK77MunU3MArPhWnRDhf_jlPaZZGgLUU8ymLJUcIHbbCdb_SwrcwZs-PtmdXQKkMtEFyDApAHmw", "token_type":"bearer", "expires_in":3600}Debug : service_persistent_storage.c:206 : Persistent: Write token in Flash
Network : ssl_tls.c:2846 : 0xc04367ac: mbedtls_ssl_flush_output() returned -69 (-0x0045)
Network : ssl_tls.c:4134 : 0xc04367ac: mbedtls_ssl_write_record() returned -69 (-0x0045)
Network : ssl_tls.c:7197 : 0xc04367ac: mbedtls_ssl_send_alert_message() returned -69 (-0x0045)
09:56:13 : Write persistent token : EVT_WRITE_TOKEN(1)
Debug : avs_token_imp.c:569 : Time 87009
09:56:13 : Token Valid ! : EVT_VALID_TOKEN(0)
Debug : avs_token_imp.c:143 : --------Got a token-----------
Debug : avs_http2_imp.c:205 : Use token (bearer) = Bearer Atza|IwEBIN1G0om_AEQXo4a9XwdOTXwU2_GYKgK2ADTnBkwtwSr7Y6XumcBH7j4HXh_CxEPll0X6YsFPmqSTrjCPbbHjmMJaYn9C2PnBULQKPOV7TasQIOxggsIbXSmKWwFxFRMl9pxg_jaLUN_ooMaJqsNyZhWnHcTt2AODL5bTF3dbykkbsf900PaFNdUFOboHg0RkRgzvY-oaPrtMrZ4zh8jrjb9OssbrT5TMAzZdZfcxDiHFCpqs9I9qoKeX8NJr6YiZgKdnPnRs7gHowkALEHZQXI9Fl_86hoebCpKhRIGpjzwJR1XJp3HzX8PVEuvsvt50ttd7Y6pZ9Tknp8yyLpXLMqqmSceu4Ey6cxbds6j...
09:56:14 : Amazon resolved : EVT_HOSTNAME_RESOLVED(0)
j2
Debug : avs_token_imp.c:132 : A Token is already available
(Repeat...)
2018-08-30 7:03 AM
Make sure you have updated the external flash content and that it doesn't contain anymore the default_amazon_root_ca section
2018-08-31 12:08 AM
Hi Emmanuel_C,
Yes, I did full chip Erase by STM32CubeProgramer before download firmware.
I use default setting to run Sdk v1.1.1 and v1.1.0, both has the same log, and LCD is always showing "Resolving Amazon..."
I only change clientId, clientSecret, productId, which are get from the project I created in Alexa's developer web site.
Use default clientId, clientSecret, productId has the same result also.
======== Below log with default debug settings, for detail error please refer my previous comment ============
Hello STVS4A
03:24:48 : Synthesizer task starts : EVT_AUDIO_SYNTHESIZER_TASK_START(0)
06:34:22 : Network time synchronized : EVT_SYNC_TIME(1)
06:34:22 : Refresh Token task starts : EVT_REFRESH_TOKEN_TASK_START(0)
06:34:22 : Read persistent token : EVT_READ_TOKEN(0)
06:34:22 : Wait a token : EVT_WAIT_TOKEN(0)
06:35:14 : Wait a token : EVT_WAIT_TOKEN(0)
06:35:24 : Token renew via the web page : EVT_RENEW_ACCESS_TOKEN(0)
06:35:24 : Wait a token : EVT_WAIT_TOKEN(0)
06:35:27 : Open a TLS Connection : EVT_OPEN_TLS(1)
06:35:27 : Amazon resolved : EVT_HOSTNAME_RESOLVED(0)
06:35:27 : Write persistent token : EVT_WRITE_TOKEN(1)
06:35:27 : Token Valid ! : EVT_VALID_TOKEN(0)
06:35:28 : Amazon resolved : EVT_HOSTNAME_RESOLVED(0)
(Repeat...)
06:35:30 : Amazon resolved : EVT_HOSTNAME_RESOLVED(0)
2018-09-03 8:37 PM
Except doing internal and external flash full chip erase.
I also remove codes relative default_amazon_root_ca:
1.service_assets.c -- assets_header_flash_base
2.service_persistent_storage.c -- service_persistent_init_default
After build, no "default_amazon_root_ca" relative codes can be found in output.map.
But still get the same log. LCD also always shows "Resolving Amazon...".
There's an error returned in avs_porting_http2_client_connect > http2ClientConnect.
How should I do to fix this error?
Thank you.
2018-11-02 2:55 PM
Has anything been resolved with this issue?
I am having a similar issue.
I followed the steps in the response above and I still am getting a certificate error.
I have tried it with and without the default certificate commented out.
Here is my log output:
Hello STVS4A
Debug : service_persistent_storage.c:316 : Flash storage empty
Debug : service_persistent_storage.c:233 : Flash storage empty
************ Start *************** : 0.0002283D"ATOR_TAP_TO_TALK0x80 }1893663a011464328487abaf660b47c6"
08:06:24 : Mem DTCM 128 KB -> 100.0%
08:06:24 : Mem PRAM 147 KB -> 100.0%
08:06:24 : Mem HEAP 3959 KB -> 96.7%
Debug : avs_lwip_network_imp.c:103 : IpAdress = 192.168.254.141
08:06:24 : Recognizer task starts : EVT_AUDIO_RECOGNIZER_TASK_START(0)
08:06:24 : Synthesizer task starts : EVT_AUDIO_SYNTHESIZER_TASK_START(0)
08:06:24 : State task starts : EVT_STATE_TASK_START(0)
08:06:24 : Connection task starts : EVT_CONNECTION_TASK_START(0)
08:06:24 : Reset Http2 : EVT_RESET_HTTP(0)
08:06:24 : MP3 task starts : EVT_MP3_TASK_START(0)
HTTP/1.1 302 Found
21:46:07 : Network time synchronized : EVT_SYNC_TIME(1)
21:46:07 : Refresh Token task starts : EVT_REFRESH_TOKEN_TASK_START(0)
Debug : service_persistent_storage.c:182 : Flash storage empty
21:46:07 : Read persistent token : EVT_READ_TOKEN(0)
21:46:07 : Wait a token : EVT_WAIT_TOKEN(0)
Debug : avs_lwip_tls_imp.c:293 : 21:46:13 : Token renew via the web page : EVT_RENEW_ACCESS_TOKEN(0)
21:46:13 : Wait a token : EVT_WAIT_TOKEN(0)
21:46:26 : Open a TLS Connection : EVT_OPEN_TLS(1)
Content-Length: 242
grant_type=authorization_code&code=ANgrptrvVKbQRFACwSjd&client_id=amzn1.application-oa2-client.8733cd06a05b40a695918f68xxxxxxxx&client_secret=37r
HTTP/1.1 200 OK
Server: Server
Date: Fri, 02 Nov 2018 21:46:28 GMT
x-amzn-RequestId: c0be5d2d-dee8-11e8-b073-8ff209c64517
X-Amz-Date: Fri, 02 Nov 2018 21:46:28 GMT
Pragma: no-cache
Vary: Accept-Encoding,X-Amazon-CDN-Cache,User-Agent
x-amz-rid: P7KA4FZW9XJJB4ZZ5SJ6
{"access_token":"Atza|IwEBIA7AMugqmZ-9Dq54B_YAxve5JvVLX17O1kvFpaYmDSz4rz26669NdDUuMtG_rKrlMXiaYFwyj-6Nj82Tmzo4C0Z-CvSjrefKhleMZXIdGlQvwda0e-KvVPh
21:46:27 : Write persistent token : EVT_WRITE_TOKEN(1)
Debug : avs_token_imp.c:569 : 21:46:27 : Token Valid ! : EVT_VALID_TOKEN(0)
Time 39790
Debug : avs_http2_imp.c:205 : Use token (bearer) = Bearer Atza|IwEBIA7AMugqmZ-9Dq54B_YAxve5JvVLX17O1kvFpaYmDSz4rz26669NdDUuMtG_rKrlMXiaYFwyj-6Nj.
21:46:34 : Amazon resolved : EVT_HOSTNAME_RESOLVED(0)
This repeats indefinitely:
2018-12-14 1:15 AM
Please try version 1.1.2.
It should solve your problem
