2015-03-25 9:39 AM
Hello all,
I 'm novice and using STM32L152RE to do a communication between 2 USARTs I use USART2 for recieving GPS Data and I would like to echo all recievied data without parsing on PC Terminal by using USART3 but I only got a unreadable character return. Can someone please help me with it? Thank you2015-04-02 1:55 AM
thanks for your response I have tested it and unfortunately it comes up only one weird character on output thank you anyway!
2015-04-02 6:16 AM
Did the original echo/loop of the GPS NMEA data work? Or do you need a different baud rate?
Perhaps you can output all the strings, instead of just the first one, or reviewing the data memory in a debugger.2015-04-02 6:46 AM
while(USART_GetFlagStatus(USART3, USART_FLAG_RXNE) == RESET); // Wait for Char
Data = USART_ReceiveData(USART3); // Collect Char
while(USART_GetFlagStatus(USART2, USART_FLAG_TXE) == RESET); // Wait for Empty
USART_SendData(USART2, Data); // Echo Char It works fine with your example above loop to echo all received data
what to do next,I want to parse the data and print out some important information like time date latitude ...etc but it 's not working
