2024-05-04 9:43 PM
I'm trying to get the STM32H750 discovery board running at 400MHz with as little code as possible. (plain C with ST's startup file, cherry-picking structs and defines from CMSIS)
As far as I can tell I do most of the things, ST's examples do before and in SystemClock_Config.
Using a debugger I checked the following registers just before switching the clock source to PLL1.
Register | ST's example | difference?
RCC
CR 0303 7025 .
CIER 0 .
CFGR 0 .
D1CFGR 48 .
D2CFGR 440 .
D3CFGR 40 .
PLLCKSELR 202 0052 dont have DIVM2 AND DIVM3;
PLLCFGR 1ff 0009 dont have PLL2,3 cfg
PLL1DIVR 103 029f .
PLL1FRACR 0 .
AHB2ENR 0 .
AHB3ENR 0 .
AHB4ENR 0 .
APB4ENR 1 0002 .
SCB
SHCSR 0 .
CCR 7 0210 no caches
PWR
CR3 500 0042 .
D3CR e000 .
CSR1 e000 .
SYSCFG
CCCSR 0 .
FLASH
ACR 37 .
After the switch my code gets stuck waiting for PLL1 in SWS.
Any ideas why the clock doesn't switch? Could the lack of PLL2,3 config be the reason?
2024-05-04 11:00 PM
Why don't you use Cube / HAL, set clock tree and debug etc, generate code and then just look, how it's done. If you can do same better, then you still can try . But have a reference, how exactly your configuration can be initialized.
