2025-02-26 2:14 AM - last edited on 2025-02-26 2:23 AM by Andrew Neil
Hi everybody,
I am having a problem with stm32g030c8t6 as follows:
I tried to write a draft program to blink the led, when I debug, the ODR register blinks but my Led does not blink. I checked on the PD0 pin and found that there is no signal output. Please help me.
2025-02-26 2:22 AM
Welcome to the forum.
You need to give some more details - see How to write your question to maximize your chances to find a solution.
2025-02-26 4:23 PM - edited 2025-02-26 4:23 PM
Does the LSB in the IDR register follow along with what the ODR register does? If so, it's working as expected and perhaps the LED is reversed or otherwise not soldered correctly, but the voltage is there. If IDR remains 0, pin could be shorted to ground, or not configured as push pull output.
2025-02-26 6:56 PM
The ISR register value is the same as ODR but I took an oscilloscope to measure at the IO pins and there is no voltage.
2025-02-26 7:07 PM
Not mind readers here. Custom board? Show your code. Upload your IOC file.
2025-02-26 8:42 PM
If IDR is high, voltage is there. It's independent from ODR.
Show your setup details and what/where you're measuring. Something is off.
2025-02-26 10:58 PM
So why don't you show your code with is probably missing MODER register setup?
