2018-04-26 8:16 AM
i am using a design with a STM32F427 100pin package, and notice after leaving the board unpowered for several hours if i power up again, the software its not starting.
If i retry the restat the power it will stil not work, only after 3-4 retries.
If i have the change to get starting the software, then if i power off/on it still works.
Boot1 - pin is left floating
Boot0 pin - is tied to ground trough a 4K7 resistor
Reset pin - is tied to 3.3V trough 4k7 resistor.
Capacitors from pins 49,73 ( V_CAP) are 100nf X7R smd type
What is causing this strange behaviour?
2018-04-28 2:30 AM
Analog supply/ground pins not connected?
The power supply pins are all connected, the ground pins the same.
How exactly did you check this? Can't there be a bad solder joint?
Software issue?
I am wondering if this is a software issue, since once the software starts everything seems to work perfectly.
Try with a trivial blinky software to exclude software problem.
