2016-06-15 7:33 AM
Hello there!
I have a running CPU and a sensor connected through I2C Interface. Everything is set in terms of hardware. Even the CubeMX configurations (startup codes) are implemented. However, I don't know how to gather data from the sensor.I wonder if you could help me,Thanks in advance. #stm32-i2c #stm32-sensor
2016-06-27 5:07 AM
Hi forum.lamer,
It will be difficult to help you unless you provide more details about your case:- what is the device you are using?- did you added the processing functions to CubeMX generated code?- when debugging, are there any error flag set?- did you checked the I2C examples available in the Cube packages?-Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
